Clicks on channels with fast Gate settings
Hello,
SQ-7. Firmware V1.3.2
There are disturbing clicks found on drum channels with Gate Library program “Drums Gate” loaded.
After investigation I found that issue is reproducible with default settings of Gate Attack = 50 microseconds.
Problem has gone after increasing of Attack value to 80-100 microseconds.
It’s not a big problem and workaround is found, but possible current issue needs to be investigated by A&H programmers/engineers.
Thank you!
Val.
Clicks on gates with a too fast attack time are normal reduce the range or slow the attack
yes, every gate with that fast attack times does that
