It is tough in a live mix to find clipping channels. It is great that the bank light is flashed when a channel clips however if it is every so momentary it is very hard to locate channel that may clip in-frequently.
It would be great to be able to have an option where just the red clip LED on the channel strip stays illuminated for a period if the channel clips - a couple seconds would do. (This could be an on/off config item.)
This would enable you to change banks and still see which channel clipped. The issue is, I flip banks, it is not clipping then after a while of no clipping I need to flip banks again to mix and then when not on the bank - guess what – it clips again…
Carl.
