Bonjour j’ai 2 surface Dlive S5000 que voudrai les utiser un comment FOH et L’autre comme MON sur un MIXRACK DM64
avec des gain Partagé sur bchaque surface?
Merci a vous.
You just need a GigaAce I/O card that you can install into the DM64. You’ll connect one surface using the built in GigaAce ports like normal (most would probably connect the monitor surface this way) and then you’ll connect the second surface using the GigaAce card. At the second surface, you’ll connect the line(s) into the built in port like normal as well.
