+1
It’s a really important feature to be able to add ducking to reverb or delay effects. This allows you to create incredibly good effects for vocals. This can just as easily be done using a compressor in the FX return, perhaps this approach is a bit easier for developers?
+1
+1 … this really needs to be available either built-in to the FX (preferred) or a way to route FX to compress them.
I supposed we could use an insert on an aux or group to accomplish this, right?
Yes, that’s possible.
You could route it through a group and use its insert or also simply its compressor.
Since a feature update was just released, there won’t be one at least in the near future anyway and so this might be a solution for you.
+1
I would definitely use compression on effects return. Would save me from having to waste a group, which I only have two of since I need the rest for auxes.
Una función que estaría muy interesante ocupar
This feature is not implemented in the new SQ+ range. Is it still something to consider? Would be great for side chain compression on reverbs for vocals!
I guess people tend to expect for newer models to BUILD on the abilities of previous models instead of strip away features to add others.
Everything is a decision and those decisions make a difference to a lot of people.
