Connect 2 computers and surface
Hello :smiley:
I have one question. It is posiblle to connect to one mix rack with surface 2 laptops? One to mixrack and the second to surface.
With IP must set in in second computer?
I have mixracj IDR 48 and surface T112
Best regards
Mario from Poland
Hi Mario
Yes it is possible to connect more than 1 Editor session to a System. Make sure each device on the network has a unique IP Address and there should be no problem.
This has been previously covered in the thread below:
https://www.allen-heath.com/iliveforum/topic.asp?TOPIC_ID=982&SearchTerms=editor,multiple,session
Regards
Sam
hey
this link not solve my problen because link in this link :smiley: is death and i still dont know how set the second pc to surface.
Best regards
Mario from Poland
Mario, You can connect two PCs to the mixrack using the 2 network ports. Connect the surface using the ACE port.
Each PC must have itโ€™s own IP such as 192.168.1.10 and 192.168.1.11.
You can also connect a WIFI wireless access point to one of the network ports on the mixrack and then connect over wireless. Turn on DHCP on the access point and you wonโ€™t have to set the IPs on the computers connected wirelessly.
Hope this helps,
Mark
ok its ok everything works great :smiley:
Mario
Make sure though that if you use wireless with DHCP that you set the range to exclude the mixrack and surface (static) IP addresses - that caused me no end of drop outs and confusion when I started with the wireless network!
iDR32 mixrack
MixRack for iPad & Tweak for iPhone apps
Asus N61 Laptop (x2 wireless)
Sennheiser IEM (for PFL)
Dante card (soon!)
