Connect QU16 to macbook
I have a QU16 mixer that I use for podcasting. I would like to feed the output from one of the mixes into my macbook so that I can use the microphone connected to the mixer (and other sound sources, iphone etc for music and phone calls) for my zoom calls. Hope that makes sense?
@Boycey
Makes sense.
Although I would prefer a PC with linux-ubuntu, a Mac should work.
Not a fan oz zoom.
But it should work if you want to use it.
good luck!
Thanks…I…guess! lol
@Boycey
did you have a question about the Qu ?
Having re-read my post, I could have worded it so it is more obvious that it’s a question! So yes, HOW can I feed the output from one of the mixes into my macbook so that I can use the microphone connected to the mixer (and other sound sources, iphone etc for music and phone calls) for my zoom call?
not again… why is every day a person asking the same without searching?
USB-B Streaming for Facebook Live via iMac
Video recording with Qu USB input
USB B LIVE STREAMING
@Boycey
How do you get input from anything external with the mac?
To do it from the Qu attach cable to the output (eg mix) you want to use.
Make sure that mix includes the mike music yada yada you want.
Read the Qu manual if needed to see how to set up a mix.
Note: pushing a mix button is like having a separate layer to adjust on the surface.
unmute what you want in and mute others. adjust levels on the ones selected.
the manual has more if you need it.
Insert adapter on the Qu cable to match the connector and level the mac expects.
From there on this is a mac problem.
Read the software manual for whatever program you are using in the mac.
