Connecting RNC 1773 to Zed 60 14FX issues.
What’s the best way to connect the RNC compressor to the Zed?
  1. Mic XLR Channel 1 input.
  2. FX out to RNC input 1
    3.RNC output 1 to chanel 2 Line in.
    This will mean the FX out signal will be Postfader. So Channel 1 gain up, fader up, FX up
    Channel 2 gain up, fader up
    I get nothing from my speakers.
OR
Sticking the FX out into a Focusrite 6I6 then into the compressor, then back to mixer Channel 2 line in.
Result nothing.
Best suggestions please.
Would a reamping box into the Channel 2 xlr maske any differrence?
Help please
Use the main L R insert jacks to patch in the RNC that would apply it to
the main mix.
Thanks Mike C,
Just make sure I’m with you on this. I have vocal in Channel 1 XLR. Fader up, gain up, Eq etc. I then increase FX out on channel 1, put a 1/4 TRS in FX out and into input 1 of the Compressor (or should I use Y TS into compressor Inputs 1 & 2 ?), and then input 1/4 TRS in the compressor 1 out( With a y ts into Main input 1 & 2, (or TS from compressor out 1 & 2 into ts Main in?)
Sorry for my ignorance.
Harle
You would use a TRS “insert cable” that breaks out the TRS plug into two TS plugs
to connect to the RNC inputs and outputs.
I think there maybe a picture of it in the ZED manual.
Here is a link to one.
Easy to make if your handy with a soldering iron.
https://www.sweetwater.com/store/detail/IPBQ2Q5–pro-co-5-foot-ipbq2q-5-1-4-inch-trs-to-2-1-4-inch-ts-insert-cable
Mike C,
Many many thanks for the input. As my first attempt failed, and before your latest response I called RNC. What a great company service they provide. While on the phone they downloaded the 14FX manual and provided the following best option that eliminated pre/post fader issues, use of the FX out (as I think that would have cut of the system FX) , or Main mix inputs etc. I think this solution is directed at A&H ZED’s due to the 14FX configuration.
This is the suggested set up for our lead vocals.
  1. The mic connects to my Focusrite 6i6 via XLR.
  2. The 6i6 connects via 1/4 TRS to RNC (the compressor) input 1.
  3. The RNC connects via TRS from output 1 to A&H Channel 1 line in.
  4. I then use Channel 1 options EQ, Aux etc just as I would without the RNC in the chain.
  5. Ignoring the mic xlr it only uses two cables, and only uses up a single mixer channel.
It worked perfectly on my desk. Before I use this live, any comments from you would be appreciated.
Harle
