Having major problems setting up our T112 and iDR 48 for the first time. Can’t seem to get all the bits talking to each other. The only thing that doesn’t seem right is that the firmware on the MixRack is 1.63 and the surface is on 1.7 (they were shipped that way). I take it that’s where the problem lies? I’ve tried the following so far…
Updating the firmware to 1.7 from the surface via USB Key.
Installing 1.63 on the surface to see if that will enable connection.
Connection to the mixrack via laptop.
So many other options I can’t even remember them now
just from experience …make sure that you connected the ACE into the right socket at the surface…they are kinda close next to each other, even with big letters ACE…but I made it happen lately
You can use a computer running editor to update the mixrack to 1.7 (instructions on the iLive download site), then try to connect to the surface again, that should fix it.
Thanks for your replies, it’s really great to know there is help out there [ ]
It turns out that the problem was with a memory stick. I tried a completely blank one and it worked fine. As far as I know I followed all of the guidelines regarding Firmware via USB card but I still had problems.
I’m now sitting mixing for the first time at our church and am loving the iLive system. We’re in at the deep end but I know that we’ll get there.
