Copy mixes
Hi.
As I have a C1500 I thought I put all my IEM mix in a DCA to easily spill them up if I need to adjust something but when I try to copy a mix to another mix (including all sends) it doesn’t take the sends when Im in spill-mode. It works when having the MIX-masters as normal channels on the desk…??? Anyone else notices this?
And also, the copy mix functions doesn’t seem to copy pre/post fader sends on channels, should it be like that?
Nothing is recall safe!
Im on 1.41
I can’t confirm this by now
but the copy mix function should copy the routing as it is
if it does not then it’s a bug
But what do you copy? If you work in spill mode I assume you have the DCA on top? So if you press “Copy” and “Mix” you’re copying the DCA not the actual mix. Or am I missing something?
You are missing something…
I will check wat is going on…
