How can I copy and paste a whole EQ section from one channel to another?
Select the channel you want to copy. Hold down copy and hit the select button. Select channel you want to paste to. Hold down paste and hit the select button.
I select the channel I want to copy from. Hold down copy and hit the EQ In button. Then select the channel I want to paste to, and hold down paste then hit EQ In.
But note, copying by pressing “copy” and “select” (of the channel you want to copy from) copies the whole processing parameters (incl. HPF, Gate, EQ, Compressor).
If you want to copy single parameter e.g. only the EQ you need to press the EQ-In button instead of the Select button of the channel you want to copy from.
