hi, i wanted to know if you can copy the fader setting from the L R mix to mix 1 or any other mixes from 1 to 10?
I found it easiest with my I pad. Double tap on LR EQ screen copy/ paste prompt will show up. Select copy. Go to your mix EQ process screen and double tap. Choose paste.
What do you mean by ‘fader setting’. Just the position of the fader?
If you want to keep the position updated all the time then a post fade with a post fade send at unity will do the job.
If you want a one off copy then you can use the master mix select button to copy send levels, assignment and pan.
Page 37 of the manual.
thanks Bob for your prompt reply
Thank you so much
