Just purchased the CQ12T and having difficulty setting up our IEM’s.
CQ12T is connected to the IEM system using a mono TRS jack lead from Out 1 to the IEM transmitter box.
Have been unsuccessful in getting Vocals (Input 1) and Btrax (ST in L&R) to the IEM box.
Could anyone provide details on setting this up this feature? Many thanks,
On the FADER page, click on “SEND TO” top right.
Then select OUT1 form the drop down menu.
Then raise your require fader you need to send to OUT1.
Click again on “SEND to”, select MAIN L/R to go back to the normal FADER page.
Click on “OUTPUT” tab to raise your OUT1 fader.
You should here something in your IEM now.
Other method:
From the Processing page of your channel, go on the sends function.
There you can raise the “Input x” to Outputs faders.
Again, don’t forget to click on “OUTPUT” tab to raise your OUT1 fader.
Thanks very much - The fault existed between the chair and the mixer** !! Me!!.** Had followed the process much as you described and had no luck. Changed lead and still no luck! Followed your first method above and all ok. Magic!! Thanks again, very much appreciated. Still have my analogue mixer head on but making good progress daily.
Don’t hesitate to test the other method also, once you’ll get used to it it 'll be intuitive.
