CQ18T PRE/POST OUTPUT PROBLEM
The pre/post selector for the outputs disappears
WHAT could be the problem?
I read a case of self rolling back firmware, check you are still in 1.2.1. or 1.2.0.
Could you describe that in more detail – perhaps with a picture?
You surely don’t mean the MainLR output, because there it’s perfectly normal, as its mix is ​​always post-fader, of course.
Uploading: IMG_5152.jpeg…
if I update the fw then it’s fine but after recall the scene or restarting is no visible, it’s there on the iPad
You had already marked the case as “solved”.
So, could it be that you’re in the wrong topic?
And there’s no image to be seen either.
This is a rare bug that occasionally occurs on recalling of a show. You can restore the button to life by restarting the mixer after restoring the show. It’s in the queue for development time and should hopefully be fixed in a future software release.
Sorry for the inconvenience, and thank you for your patience.
