CQ4YOU does not connect but CQMIXAPP does connect
Hi. Anyone else have this problem?
I have an ipad. Both ethernet or wifi, same results.
CQMIXAPP recognizes the device and connects however on the same device, the CQ4YOU app does not recognize the device. Nor will it force a connection when the IP address is known over ethernet.
This is so frustrating!!!
@Jjs3834
Check that both apps have access to local network in the iPad privacy/security settings.
It may be that you agreed to allow access to one the first time it was run (you usually get a pop-up), but not the other, and will therefore need to allow it manually.
thanks. sorry I never saw this response.
