CQ4You - save settings between mixers
Am I wrong, or is there no way to save a monitor mix?
Use case: playing with 2 different bands, 2 different CQ18T mixers – right now, I have to re-establish my entire IEM mix every gig/rehearsal.
Surely this was thought of?
Unless you’re recalling scenes that are overwriting the adjustments you make to your IEM mix then the mixer should stay in the same state it was when you last used it - it will only reset mix settings if you recall a scene that does this.
You can always save your settings as a scene once you’ve made your mix.
Hi, I should have been clearer: I am using CQ4You with two different bands, two different lineups, two different CQ18Ts.
In one band, I’m playing keys and singing, in the other I play bass. One band has a fixed lineup, the other has different soloists that sit in on channels 14,15, or 16. How do I toggle between the IEM mix I’ve set up for band A to the mix for band B without re-building them every time?
Apologies if I am missing something dreadfully obvious, but there’s really nothing I can find on this topic.
Aha, I see what you mean. You’re right that there isn’t any way of achieving this right now. The app will get the correct levels from the mixer but there is only one configuration for the dial assignments.
Yes - I agree that this is an issue. I’ll pass this over to the product management for the app.
Thank you. I am about to have the same problem. I have an old phone I no longer use. I will have to see if the operating system supports CQ4You.
