I have been expereinceing a crackling sound in the t=right channel of my Qu-16, which sounds like a bad tweeter breaking up, that happens at peak levels only. My main meters are top redlighting, and the left channel syas clean. I switched out the right speaker, thinking it was the problem, but go thesamething with a different one (make and modelnot important here).
Has anyone experienced this with their Qu, and might it need service? I need to so some more testing, but it is odd andbotherasom,e as sometimes I need the levels up to cover alarge outdoor yard or hall…
You admit to “redlighting” the mixer but complain about distortion!
You need to look at the gain structure of the rest of your system.
What’s the rest of your system, speakers, amps, processing.
Oh damn, Typo! NOT red-lighting, it is crackling at only plus 1 or 2 yellow LEDS). NOT overdriving it, which is why it is weird. Sorry for the ypor(typo)! I should have proofread it. I wish I could edit to correct the several typos!
And the left channel does not make that sound.
QSC K12, EV ELX 112P, and ZLX-112P all show it the same, and I’m running subs off aux 9.
I have tested the speakers on another system and they go way loud with no crackling. Next I’m going to run yesterday’s show at the same levels with various speakers…
Check meters throughout the signal path.
Send a single time through the output and listen at various levels, passit back into an input and record it on the QuDrive to visualise errors…
It stays on the right main output. But people, I was NOT asking how to figure it out or what steps to take, I was asking if anyone else has experienced an output problem in only one makn output channel.
OK - But you said:
“Next I’m going to run yesterday’s show at the same levels with various speakers”
so it seemed you’d not yet figured out if speakers (or their cables etc) were the cause of problem.
To answer your question though, no, I’ve never had any problem with the outputs on either of my QUs.
We just want you to be sure the source of the problem has been isolated.
At an install I know of a QU32 that has low output on left channel of mix 5-6.
That mixer is in a church that took a major lighting hit that took out a lot of other equipment in the building and wonded the mixer.
Did you solve this problem? I have the same problem.
The crackling sound is on the right side… speaker and also in my headphone… so this means it’s not an external problem…
Another problem is that there’s no outgoing signal on my main output… at my birthday party I had to go on the monitor output to save the evening :-/
