Hi there people.
I’m sorry for the exceptional newbie-post, but I’ve been thrown into the ring here with very little knowledge of digital mixers, and have read posts for weeks (and done tests) without coming closer to a solution.
Also, I hope this doesn’t show up twice, the first post I made never showed up on the forum.
Hope some of you can help with our most pressing issue, as our supplier has been unable to assist, and I’ve only gotten so-far with the manual and online tutorials.
To explain a bit:
I’m connected to a radio-station who recently has purchased a SQ-5 (not the right rig for this gig, I know, but that is out of my hands - and not something that can be rectified. We have to work with what we’ve got).
It is currently set up as follows:
Layer F is set up with 3 channels for microphones, a channel for the phone input and one for the output from the computer supplying the music-mix, commercials and such that’s coming in through USB.
One channel is set as pre-listening with the complete mix out to the studio monitors.
One channel is set up as the complete mix OUT via USB - back to the computer which process the mix and encodes the stream.
So far so good - all that works as we want.
What we need is a separate layer to work on WHILE the broadcast is active.
It needs all the direct inputs (microphones, phone (and preferably one direct input from the computer as well) - and output through a channel that we connect to Soundcard2 on the computer.
That way we can record all microphones to the computer, cut and mix, and thereby create content WITHOUT it going on air until we’re done.
I have tried this, set up the Layer, got it all (seemingly) working, with no sound out on the channel that goes to the Encoder. This was done while the broadcast was served on a seperate computer, to work undisturbed.
But when we reconnected - whatever we did on the new Layer was sent on-air…
How can we avoid that, and create a setup to work and record OFF-air ?
Sorry for the wall of text and the lack of knowledge, but we’re getting a bit desperate… hope someone can be able to shed a bit of light on this. And please adress this as you would a child
- I’m not up on the technical definitions yet. I’m just trying to help a bunch of enthusiasts.
