Cubase 10 playback
Have Cubase 10 and trying to playback via USB to my SQ-5. Have the SQ USB ASIO driver installed but when I go to Cubase settings only see 2 channel L&R, am I missing something?
Also when I do playback to the 2 channels the audio sounds like it is playing at 78rpm.
Possibly in Cubase, you have input set to L/R and not to all available channels. Pretty sure that the speed problem is because you have not set the project to 96k, it’s probably 44.1 the default
Can’t find anywhere in cubase or the sq asio driver to select any other channels apart from l&r.
Tried changing the project to 96k and still the same result.
You have make Inputs in F4 - VST-Connections - Studio
Yes but only see 2ch out, can select the 32ch inputs when creating a new project but can’t select the 32ch individual outputs back to the desk.
