On the Fader page of the CQ, is there any way to have custom channel strips on a single tab? What I would like is to have five microphones plus usb and bt on the same tab. I don’t see a way to do this but just making sure.
It is not currently possible to set up a custom layer, but it is just one of many feature requests. So hopefully it may come in a future update.
So for the time being I would recommend that you try out the Mixing Station app that will let you do just that, it is a fully customisable app.
I agree with Lee7. I have aquired Mixing station on my iPad and got to work on it. Is a learning curve but I got there including an Akai MidiMix gizmo hooked up via usb midi. I now have a physical version of what you seek. Was another learning curve again bit I have even got the button leds to illuminate when mutes on/off. I now have sub group Dcas working and corresponding group mutes along with the MidiMix buttons giving me Drum groupe vol and mute, backline group vol/mute external fx/voc processor/harmoniser, dj input and the 4 vocals on individual channel vol and mute. The MidiMix also has three rotaries you can program in tho I found the pan completely unusable, but you can use to adjust the FX sends or other CQ features that are available on the Mixing Station app. Very handy setup and will suffice for now and MS does not coast many pennies, about 6 pounds in UK
In Mixing Station is there any way to have the Main fader appear along side the channel strips? I only spent about 15-20 minutes on MS but I did not see a way to do this. I also did not see how to reorganize the channel faders. For example, I want the first five mic channels plus USB, BT, Main LR out and Aux 5-6 out all lined up on the same page. Then I could just leave that up all the time and have access to all faders without a page flip. Thanks! Appreciate the help.
