Hi folks,
Today I tried to build a custom control layout with 10 PFL buttons and a fader assigned to a program mix.
This program mixes lives under Mono Matrix 18. When trying the layout te fader greyed out. Also trying to assign a dynamic label from Matrix 18 did not work. Does anybody know if there is a limit to Matrices is CC App or something? Mono Matrix 1/3/4/5 I could find but higher was no joy.
I created a workaround with DCA 24 but I still don’t understand why this is not possible.
Anybody had the same experience? TIA
Hi Jh3500,
Do you have 18 Matrices in your DSP config ?
You could have 62 Matrices on a dLive system If you have created these in you busconfig.
If the Busses are not created it shows up as a Yellow/Grey striped item when online.
This means the Control object has nothing to control (Bus is not created, Wrongly assigned etc).
DCA’s 1-24 are always there as they are part of the fixed system.
Hi Martijn,
The matrix no 18 was definitely created and sending audio. But I still couldn’t assign it in CC.
I saw your reply just now so that’s why I haven’t replied earlier
Hi Martijn,
