Hello all, I recently started helping out at a church running an Avantis system. I’m not the sound guy myself, but he hasn’t ever messed with Custom Control so he’s not sure what to do here either.
Basically, I’m trying to be able to control the levels for my belt pack that’s running through a Stereo Aux channel on the board. I thought that if I set the faders in Custom Control to “Send Level” rather than “Main Level” and set the Destination Channel as the proper Stereo Aux output that I would be able to adjust my in-ears without bothering our sound guy every time I need something adjusted, but instead it just gives me the yellow lines across all of the faders.
I also tried swapping the Channel with the Destination Channel to make sure I didn’t just have it backwards, but the issue remained.
Am I doing something wrong? Is this a functionality that just isn’t supported with Avantis yet?
I’m not in front of the board at the moment so I can’t verify the Avantis firmware version, but I’ll be there later today.
I created the layout with Custom Control Editor v1.1.1 for Windows.
Attached a screenshot of the editor so you can see my settings on the fader.
I already found out that the Dynamic Text isn’t working yet, I just hadn’t changed it yet when I took the screenshot.
