Building a layout to allow us to monitor & PFL(2) 32 radio mics remotely.
Set up is working but I need a PFL Level control - added a fader to the layout but can’t find a function to assign
Thoughts?
Thoughts?
You can feed the PAFL into a Matrix or aux thru the EXT in (Make sure you do NOT PAFL this bus! ;-))
use the outs from the matrix or aux as your PAFL feed, set the level in CC to the right bus and you should have level control.
(An other simple option is that you probably have a headphone amp/IEM pack that has its own level Control?)
