Monterey not working with the custom layer on my Qu32. I updated to Ventura and it worked for 2 weeks and then stopped working, so I switched back to Monterey OS and it still does not work.Allen heath site states that it should work with Monterey.
I presume you’re talking about using the custom layer for MIDI/DAW Control?
In which case, there should be no issue with the USB connection for audio and MIDI as this is class compliant.
A&H MIDI Control is not officially supported on Monterey (please let me know if you’ve read otherwise) but saying that, we’re also not aware of any issues with it.
I’d suggest trying a fresh reinstall of A&H MIDI Control and a check of the setup.
Also double check what is assigned on the custom layer.
You can then see if there’s messages coming in from the Qu and move on to checking the setup in the DAW (based on the MIDI Control help doc).
Hope your well, hate to bother you, I have attached a picture of my desk and am wondering what these lights mean, I setup DAW control and this happened. Don’t know if you received the picture, but channels 1,9,17,and 25 green select lights are on and they seem to be synced to each other. When I select a channel each of channels move in unison.
