I have an avantis with the ME monitor system. I’ll be adding the 64x Dante card as soon as they are in stock and I have two questions.
Can you run the Dante card at 48khz while the slink connection is at 96khz? (using a gx4816 and dx4816). So I can use 64 channels into Dante virtual soundcard?
Can you output dry pre-efx/processing on the Dante outputs and a wet post-efx/processing on the ME outputs?
We want to be able to run monitors for the band with eq and verb and a dry output for our pro tools broadcast rig.
