Hey, what DAW that supports QU or vice versa.
DAW control on the Qu-series is compatible only with Apple Mac computers.
The drivers are native to Macs and any DAW using HUI or Mackie control protocol can be used.
More here:
https://www.allen-heath.com/key-series/qu-series/#tab5
Although you can’t have DAW MIDI control on Windows machines, you can stream via the USB port to audio software such as Adobe Audition, ProTools and Ableton - others available!
This allows you to record in multi-track format and replay to the mixer but you’ll have to use the computer for machine control and take the replay inputs on to the channels as USB inputs.
You will need to install the Windows ASIO/WDM drivers also available on the link above.
