I have an iLive system and had configured two iPads for use with it via iLive OneMix. Both iPads were stolen. Bad on us, we do not have a record of the iPad serial numbers. We are attempting to recover information that would uniquely identify the iPads, either by serial number or MAC address. The iLive system can uniquely identify each iPad that connects to it via WiFi using the OneMix app. Is there a way to decode the show or scene configuration files to determine the SN or MAC address of the iPads that have been configured to use OneMix with this system?
If you have access to your Wi-Fi router’s administration interface, you might be able to view the DHCP client table on it. This would show you the IP address given out by the DHCP server for each MAC address. My iPad has a MAC address starting with BC:3B:AF so yours may too (the top half of the address is assigned to each manufacturer), so you’ll know which addresses to look for (if those were the only iPads getting IP addresses from your Wi-Fi routers).
