DEEP Proc. Plugins
Is there any way to transfer, uninstall or remove activated DEEP Processing plugins ?
thx
-Chriss
Hi Chriss,
No - Add-ons are unique to each unit and installed at low level, so they are not affected by firmware updates or system resets.
Greetings @KeithJ_A&H
If the add-ons are installed at birth/ manufacture of each Mixer
Are those add-ons upgrade-able in new version numbers?
@Schneich
Why would you want to remove the Deep Plugins?
Greetings @xyz :slight_smile:
Add-ons are installed by the user and can indeed be changed/improved/upgraded through firmware (as with the extra modes added to the De-esser with V1.5).
It’s just the installed/not installed status which is unaffected by changes or updates. e.g. you do not need to re-add all your add-ons after a factory reset.
Cheers,
I want to take them with me to a different console which has none
As noted, that unfortunately isn’t possible. The plugins are licensed for each individual device and are non-transferable.
Yeah - what’s missing is a “de-authorisation” mechanism. Stops the 3rd party trade of plugs I suppose and protects revenue for A&H. Fair enough but I do see why the OP would want this. If I’d bought a load of plugins and then wanted to change to an SQ6 or 7, or a new SQ5 with no scratches or faults, I’d be a bit sad.
I dare say if you could show that the old desk was beyond repairable, A&H support might be swayed!
