Is it possible to set a default (possibly with the next update) so that certain settings don’t save with a scene?
Such as: removing main mix processing, delays, etc from the scenes? As is, we copy/paste/update to accomplish this - I would just love to be able to limit what is saved with the scene.
In the editor "scene editing"or pdf “scene memories” page 78, you can choose what to save or change within each scene… its quite extensive!
But then you have to copy and paste that setting into the other 250 scenes. I think. I don’t see a way to set a default that carries through all scenes automatically. Sort of a scene template. Unless I’m missing something.
I was really disappointed to see no enhancements to the scene manager in the new version. There have been a lot of requests here that fell on deaf ears.
Yeah I’ve requested it before also - We need a scene save library so you can set up templates of what gets saved. Even just a couple of customisable scene save buttons would be good. The current method of copying/pasting scenes and then updating is cumbersom - not to mention that copying a single scene to many is difficult and has to be done in multiple steps.
I’d like to be able to arrange my saved scenes just like in an explorer window, with folder possibility. Then Make PLAYLISTS of scenes just like in mediaplayer for the actual shows.
Plus indeed a few dedicated scene save buttons, so you can decide on the spot what KIND of a scene you are saving. Then this ‘kind of scene’ should be easily readable in the scene explorer, just like file properties in the Windows explorer.
David Schmoldt
Sorry for misinterpreting the original question…what is needed indeed is possibly something like the snapshot save prefs feature in digico sd9 and 8…called "Global Recall scope"as well as the timed scene recalls and scene crossfades and the “Select update range” in the sd8-9 prefs, so all snaps(A&H scenes) are updated …??
While we are on the subject of scenes - It would be also a great feature to be able to add or remove selected parameters from all or from selected scenes (in one step)
Or in other words - select the parameters you want to add or remove, then select the scenes you want to apply that to (or select all scenes option), Then Apply (with an idiot “are you sure??” message of course!) This could also be achieved the other way round by first selecting the scenes(or all), then selecting parameters to add/remove > Apply
That would be a GREAT feature! I just don’t see the scene manager issues getting much attention from A&H. I’m guessing they don’t use them very frequently in the A&H shop.
