delay i/o
the input and output delay is too coarse, it should be at least 0.1ms and not about 1.1 ms
mah this morning sq6 woke up with delays operating in steps of 0.5 / 0.6ms, better but still too much
I second that! For time aligning mics, for which input channel delay is used most i guess, 0.5ms steps are too big. Is there a trick to finetune it, which i haven’t found yet?
On the surface, the touch-and-turn knob adjusts delay in a very course way as you describe. However, on the MixPad App it is possible to get 0.1ms control, but touching the control, dragging your finger away from it, and moving to the side.
Unfortunately the MixPad display rounds to 1ms, so you have to stand looking at the surface as you control it on the iPad. However, as a workaround it does work.
thanks for the reply but I use an android smartphone as remote, the delay frame is too small, it would be more functional to be able to
enlarge it to work better.
Thanks ben, i’ll try that!
