Did not understand effect flow for pre-fader monitor
Hello, we start using CQ 18, replacing analog Yamaha.
We generally only use reverb for singers, others instruments are independants.
In the workflow, we sent stage monitors in “Prefader-Mode”.
I understand the equ and reverb canb be setup for eatch, but is it possible to have the same main effect setup ?
I’m searching an option “Same as chanel” FOR EFFECTS ?
Thanks for help.
Please have a look at the block diagram (see picture):
Yellow is the path from a FX via the FX return fader to your main.
Red is the path from after the FX return fader to a fader with which you can set the FX level in the IEM.
If you have done that, the FX level in the IEH will almost “automatically” always follow the FX return of the main.
I hope that is what you mean.
