Difference between "Direct out" and "Insert send"
I did got the solution now in another forum :slight_smile: : The I/O USB patch must be set to Insert Send for raw recording without further processing, and then the Global Direct Out setting no longer matters (or I select USB Patch Direct Out and Global Direct Out Settings “Postgain”, which is the same thing!).
https://www.musiker-board.de/threads/qu-16-erleuchtung-zu-den-usb-i-o-patch-und-global-direct-outs-einstellungen-erbeten.765418/#post-9931721
