Difficulties with Dante
I’ve recently got 3 Dante cards for all my systems, have set up FOH/ Monitor arrangement. I got signal from one unit to another but there are pops and clicks in all channels repeating with random sequence. I was looking into Dante Controller, but only thing I could do there is change interface name and do patching. When opened Device status and Clock status (which is the issue in my case, I think) nothing is shown there. Anyone had similar problem?
Hello All!
Any updates on this issue as I face similar problems running Dante…?
Installed in Port B (IDR32/T80), Dante is shown in the Port B window. While watching under “Expander” is shows a message in red saying “incompatible option card”. The firmware is 1.83. When set to recording with my MBP and Logic I get all the signals, but with random clicks over all track as ddff_lv described above. The Audio signal is avaliable on all desired tracks. Further, I can NOT see or change any setup details in the controller. Obviously the major reason for having the clicks.
It simply does not show any status messages for clocking and so on…
Whether the IP config is set to manual or not. Any help for an old analog guy? :smile:
Thanks to everyone including A&H for the forum. It was helpful for several questions already.
Mike
Mike,
my solution was installing controller on different computer, then I was able to set one dante unit as preferred master and slave to ext wc (i.e. iLive system), the other would stay as slave, then in other mixrack you tell to sync from port B. Then connection between mixracks works fine, haven’t check for longer time to estimate stability, but so far found no problems. Controller software on the particular PC still cannot be used- tried to remove/install it in different ways- no luck. I think there are place for improvements here.
I’m still having huge problems with DVS and recording things and after 2 months and more than 10 different computers and different recording software I’m about to declare this process being incredibly unstable and unpredictable. I really think this DVS is a bottleneck in whole thing, maybe a piece of hardware (PCI-e, ExpressCard) would bring some improvements. Or even better- some HW recorder that accept Dante. So far there is just JoeCo, but it can record up to 32 channels. Another machine is AES50 recorder from Klark, however then a network bridge from Dante is necessary, then it turns out to be quite expensive. But as they say- you don’t get anything free…
ddff
Hello,
thanks for the very quick response. This is, unfortunately, not the answer I was looking for. :frowning_face:
The solution can not be a new installation on a different computer. Not for the product’s price tag. The basic set up seems to be correct as Audio can be transfered…it is just the controller part of the firmware which is difficult to get running smoothly.
Does anyone use DANTE in combination with a MBP? Any similar experience?
I want to record next week and I do not want to run my HD24 if I own Dante.
Mike I had a problem initially setting up Dante on a MBP. See here: https://iliveforum.allen-heath.com/topic.asp?TOPIC_ID=1619&SearchTerms=Conmon
Cheers
Richard Howey
Audio Dynamite Ltd
Hello Richard!
This sounds quite the solution I’m looking for!
I did not find your entry while a was looking for information. Sorry.
This is quite tricky thing to figure out… :wink:
Thanks for your help!!
Mike
Hello Richard,
it sounds just like my trouble I got first time working with dante.
Some hints from me, even they are know:
The ConMon issue I think is only relevant to old version of DVS and Controller. Make sure to have true latest versions installed (DVS=3.2.1 Controller= 3.1.2)
Random clicks in Audio are due to wrong system clocking. Only one system can be the master in the network. If you’re working with more than one MixRack make sure one is set to audio sync=internal in mixer preferences. Other mix rack set to audio sync = port B (=dante)
Make sure that in dante controller app the iDR which is set to audio Sync = internal is tagged as “preferred master” at clock role and slave to external word clock is tagged.
I’ working with a setup quite similar and two MBP’s for recording, running very reliable. I use different DAW’s related to customers preferences ( ProTools, Logic, Cubase. Reaper) all latest versions/releases.
Additional and good infos are to find at:
Understanding Dante and iLive →
https://www.allen-heath.com/UK/CategoryDocuments/Understanding%20M-DANTE.pdf
M-DANTE Getting Started Guide →
https://www.allen-heath.com/UK/CategoryDocuments/ap8340_1%20M-DANTE.pdf
iLive and Dante Webinar - Part 3->
https://www.allen-heath.com/Assets/Pages/videoplay.aspx?FileId=https://www.youtube.com/v/i59m3qLR7NQ&rel=0&autoplay=1&hd=1&showinfo=0&enablejsapi=1&playerapiid=ytplayer&fs=1
Happy recordings!
Gunter
Günter Eisbach
dL-Recording
Darmstadt / Germany
do you run dante controller from a computer wich is plugged in on the left of the dante ?
(thats where you should plug it in if you do not connect a computer for recording/playback)
in dante controller you have to tick both sync options!!(very important)
clock source within your ilive rack should be internal (this you have to do on your i live.)
if this is set the controller automatically sets one of your units to master and the other to slave.
cheers
dave
allen&heath iLive-144 /idr 10 / idr 48 /dante (i want midi in dante!)
Yes, I was connecting PC to Dante Controller socket (non-Neutrik). The next socket (Primary) was used to connect two iDR racks together.
Problem with sync in Controller software was I couldn’t see any clock settings and also couldn’t change it. Only parameters I could view/change were interface name and routing. On the iLive systems I had internal clock selected for both consoles. I had some discussion with Audinate people, they suggested to uninstall and then reinstall Controller software, then suspend AVG as it is believed to disturb this programm - so far no success.
ddff
Hi ddff,
I see you are trying to link two mixracks together with Dante so that FOH and Monitor racks can share analogue inputs digitally.
Before you get involved with the Dante side of things you should pick one ilive mixrack to be the main rack (I would choose the rack with all the analogue inputs/mics connected from stage) and one to be the secondary rack. By default both racks will be set to sync to their internal clocks, which is correct in the main rack, but is now not correct in the secondary rack in your linked system. The second rack in your system is going to be receiving its audio across the Dante network, through the Dante card in it’s port B slot. This mixrack should have it’s clock sync source changed, to sync to “port B”.
The next step is to set up your network, and start Dante controller (and if you have patched inputs and got audio flowing you must have done this). Open the clock status tab in Dante Controller. There are not many options, but there should be two check boxes (Clock Role and Slave To External Word Clock) shown after both Dante devices in your system. Pick the Dante device installed in your main iLive rack, and tick both boxes, which will make it the master Dante device receiving it’s Word Clock from the main iLive rack. The second Dante card will automatically become a slave, and will automatically receive it’s clock from the master Dante device, therefore the check boxes on this card should be blank.
If you are having trouble with the devices and Dante controller talking to each other on your network, you could try checking that the DHCP settings on your router are enabled, and that your PC running Dante controller has it’s IP address set automatically by DCHP, as this helped me when I was unable to set channel subscriptions.
I hope this helps
Steve
if you have no clock setting on the dante device, so it means that it does not uploaded right in the dante network, so go to DEVICE(or command D)/ browse from the list your device /config/ then make changes that you need, then reload device.
then device should appear with all parameters changeable:)
agutin.com
2x iDR32 +MADI OPTION
MacBook,
desktop+2x RME HDSP MADI 2 X M DANTE CARDS
I found out that running Controller software on different computer I got all the parameters available so I’ve set all clocks right (according to Dante user guide) and now everything works fine. I also found out if NIC adapter has static IP I get same picture- can rename interfaces and do patching, everyting else is blank. Still can’t figure out why it’s not working on other laptop even if all the settings are the same, except one has Windows 7, other XP.
ddff
I guess it was the XP system that worked?
nope, XP was not working. Tried with and without AVG running and several times all components uninstall/install.
Maybe because Bonjour is used i have to reconfigure something in DHCP node type or somewhere- Dante truobleshooting doesn’t have any hints.
ddff
Are you joining your mixracks together with ACE, or Dante?
John
System Integrator
Entertainment Arts Inc.
Systems are joined via Dante. Typical FOH/ Monitor arrangement.
ddff
