Direct usb out routing for running sequences on my SQ 5
Hello,
I am planning on using my sq 5 as a monitor console for upcoming shows. I am using the soundcard of the board to run my sequences from my macbook pro. I am using reaper realive and I have 5 stereo tracks coming in the SQ 5 by usb inputs. I am not sure how to route the USB inputs to the outputs, as I need to use 10 outputs as “direct outs” to send the sequences to FOH . I have a GX4816 and I am planning to use the outputs of the GX for sending the tracks to the FOH and the SQ 5 ouputs for the PSM 900.
Can someone direct me where I need to go on my console to correctly route the 5 stereo USB inputs to outputs 1-10 on the Gx?
Thank you!
If it is just plain routing, you should use Tie Lines in the I/O patch
