Just installed 1.98. Seems to work much better, and looks better, on this Macbook Pro M1 with Sonoma. However, I’m not able to select mixrack/surface. DM64 + S3000 is chosen by default…all other options are greyed out.
Unfortunately this is a known issue that was found after release, and will be fixed in the next update.
The workaround is to select your mixrack/surface in the Offline setup once Director is running.
ummm. How? I cannot really find an option for changing it once the software is running (running on mac) Thanks!
Go to SYSTEM click on OFFLINE tab , there you can change the rack and desk.
