distorted signal
I am having a problem with my signal going from the Dante Card in my IDR16 going into my Macbook running Pro Tools 10. Within 3-5 minutes of opening a Pro Tools session the signal begins to be distorted and by 10 minutes the signal is completely gone. When I restart Pro Tools the process starts all over again. Has anyone else encountered this, or have any suggestions?
I have not had this issue with my iLive, but Sounds like it could be a clock issue.
I had similar with my previous set up (which had a clock issue).
Could you describe your system?
If you do, i can direct you to a proper clocking setting. If that is your problem.
Gil Parente
Design & Integration
Entertainment Arts, Inc.
iLive 176, T112
iDR48 , iDR16, iDR10
Multiple iPads
Dante
Etc…
It sounds like an ASIO problem, not related to clocking…???
SRV-AVB
R-72, iDR-16, xDR-16, Dante
The setup is:
iLive T80
IDR16
Dante
MacBook Pro
Audinate Virtual Card
Pro Tools 10
there is also an iLive T120 → IDR 64 → Dante which is networked to the above setup and the master of the two setups, but isn’t being used in reference to the macbook and pro tools
Thanks for all the input, I found the problem, it was a simple oversight on my part with the clocking. All the comments made me think to go in and check the clocking for the millionth time and I found the one assignment that i had somehow overlooked and now all is well. Thanks again.
quote:
Could you give some details, this could be useful to other users…
Thx
Ray
