DIY external midi controller for the CQ
Okay totally new to all of this but can this invention be used to control a CQ20-B from something like an Akai APC40 MK2 or similar? I was thinking that by driving the mixers web ui it would essentially be possible to do nearly anything you ‘just’ need a way of mapping the Akai (or other MIDI devices) controls to the correct control in the Mixer. Did A&H implement MIDI controls? I remember it was in the USB sound driver but didn’t do anything initially. Is that what NRPN is referencing? Sorry for the dumb questions. Also the mixer is for live gigging usually just to mic the band, provide IEM for them with click tracks, and then feed front of house it all nicely mixed for consistent sound across venues but in a home studio situation it would be nice having a control surface and I happen to have the Akai…
I don’t know much about the Akai but they should output some midi for sure.
You could also get the app Mixing Station that allowes to map any MIDI controller to whatever you like. Obviously you need a phone or tablet connected.
I should have done some research before posting but I’ve got it sorted now, at least logically, I can use Bome (or other software to map the Akai to the CQ and back). Also as the Akai faders aren’t motorised but the knobs have led rings, or you switch scene, you can set the ring led’s based on the CQ’s setting. So it looks like I’m ‘good’ and with a little fiddling should end-up with a nice set-up. I like what you’ve done though and Bome make a BomeBox which is essentially very similar for operating without a computer. Thanks for the super fast responses btw.
Yes, this is exactly the purpose of this tool.
But bome is more “straightforward” and easy I admit.
