Dlive action Layout recall issues
Hi everyone,
I’m having some issues with recalling Fader Layouts using Actions. I’ve saved several different Fader Layouts, and when I recall them directly, everything works perfectly. However, when I try to recall them through Actions the Fader Layouts simply don’t recall anymore.
What’s strange is that everything did work correctly during the programming phase. I tested it several times, and it was working exactly as expected. But after doing a full show, it suddenly stopped working — so I might have accidentally set something up wrong, but I can’t figure out what changed.
To summarize:
Recalling Fader Layouts directly works fine.
Recalling the same Layouts via Actions no longer works, even though it did before.
Additionally, I’ve noticed another issue with the Scene Manager: when I try to label or rename a Scene, the on-screen keyboard gradually disappears after a few scenes, making it hard to finish typing or to aply/cancel.
Has anyone else run into these problems or found a fix/workaround?
Thanks in advance for any help!
With regards the keyboard issue, that is a known bug, and is on the list to be addressed.
And the other issue?:melting_face:
I would suggest that you submit a bug using the official support method (using the support tab on the main A&H website). This is simply a user forum and while A&H employees do monitor posts here, it is not official support for A&H.
