dlive groups
Hello, I’m new here… (a&h dlive c1500)
Can someone explain step by step how to send a signal to groups (not dca)…?
A big question: is it possible to buy libraries, presets, channel settings, effects, etc. somewhere? Regards !
this will answer many questions.
First, because the DLive buss structure is flexible, you need to make sure you have set up enough groups for your needs - Config/Mixer Config. You can name these groups under Config/Name & Color. Then you need to assign inputs to a group via the “Routing” section (page 41-44 of the firmware reference guide)
