dLive Mix follow PAFL on SoftKey
Hello,
forum newbie here.
I’ve used dLive for some years now and i think something is missing in the mix follow PAFL system.
When PAFL of an aux is assigned to a soft-key, the mix isn’t following the selected PAFL (although the option is on in the PAFL settings).
That could be a big implementation.
In my usual monitoring workflow(s5000 or s7000) i keep all the inputs in the 1st and 2nd bank; the 3rd bank is for aux masters and VCAs, in two layers.
Having the possibility to call PAFL and mix with the push of a single soft-key would help to reduce the swapping between layers.
Thanks in advance for your reply
Select Mix PAFL Scene is what you’re looking for I think.
