Dlive shared effects
We recently had 2 C3500 consoles installed. One for FOH and one for livestream. They share the DM64 mix rack. When the installers set up the consoles they linked the effects between the two consoles. How do we unlink the effects so there is independent control between the consoles?
How did the “Link the effects”??
@Charlesh214
The DM64 Mix Rack is the mixer, so the 2x C3500’s are controlling the same mixer.
A multi-surface setup like this can be setup and used in many different ways, but it might be that you are accessing (for example) half the input and output channels on each surface.
You could therefore do something similar with the FX, by just ensuring FOH uses FX 1-8 and Broadcast uses FX 9-16.
Unless by ‘FX’ you mean the channel processing?
In which case, you may need more in depth assistance with the whole setup, so I’d recommend getting the installers/integrators back in to finish the job!
(you can also contact us directly via support.allen-heath.com)
