Now that we have this great new function on the dLive, what new Functions would people like to see in Actions-Functions list?
I’m already using Action to turn ON/OFF BYBASS of Vocal Tuner. I really like the way that the colour changes on the Softkey. Could the colour be user defined? As in Blue OFF Pink On? Or vice versa, if somebody likes it that way?
One on my wish list is Virtual Soundcheck ON/OFF Toggle, with similar safe-timing as SIP has
Please throw your ideas here!
I wasn’t able to install the update yet, but isn’t the vocal tuner only available with the new fx card installed?
Or did you already get one?
Yes! A few got shipped to Scandinavia so been able to start using the UltraFX Suite already. Works really well.
I’d wish for recall of specific library presets on specific channels. such as eqs gates comps etc. Going from singing to speech for example…
I mean if it’s a setting that can be changed on the console (especially any audio settings), then it should be changeable with both softkeys and scenes. Unfortunately there are MANY settings that aren’t currently.
Brian, Could you be a bit more specific?
It will take a lot of time and resources to program Everything to be in the Actions - Functions list. Let’s at least let A&H know the most wanted ones by the user community
I would like to be able to quickly switch between two different I/O configurations. We record rehearsals to Pro Tools on the FOH computer via Dante, then reconfigure the I/O to send the tracks back to the second dLive in the studio via tielines so the Stream Mix Engineer can continue to tweak his mix. It’d be nice to have that I/O change be a one-button-click.
id love to see pre/post options for all inputs, if im building a new showfile for FOH and mons, the ability to give a single file to both users and be able to have a macro to change aux sends for mons to post fade for their own configuration would be great
I get what you are saying, and any addition to the actions is a good one for versatility, but just to check that you know there is a quick way to change mixes from pre to post?
Press and hold the PRE assign button, and press the MIX button for the auxiliary you want to change.
Or it might be:
Press and hold the PRE assign button, and press the SELECT button for the auxiliary you want to change.
It is one of those, I can never recall and just mash both until it works. I’m not at my desk to check.
@ShadowSound yeah i do know that shortcut, like you i can never remember it… and i swear about it every time!! Haha!!
