Does anyone have any ideas if, like there was for the iLive the website for uploading the show file from an iLive system and printing out a .PDF showing the I/O patching etc, a similar website where show files can be uploaded to view and printout .PDFs of the patching etc? Would be quite helpful??
www.ilive-t.com/viewer is the website - a very useful tool!!
That’s a very cool tool… that I never knew existed in all the years I’ve had iLives!!! It looks like it was a 3rd party developed tool, maybe if that developer gets into a dLive they’ll update it?
Can someone please post a link to a sample PDF?
I’ve worked out 30 output patch pages and 27 audio sources in 1.41 so far, not counting the fact that that the surface is 1 output patch and 1 source (analog, aes, dx, slots and usb).
My output is quite crude at this time and making this readable is next on my list, both for “output from source” and “source feeds what outputs”. Quick format was going to be a CSV, but a PDF is in scope.
Jay
I’ll try and find a pdf from previous outputs but as haven’t used or needed to use my old iLive for a while now due to the dLive being here I’m not sure I have something available!
While I’ve used Ilive viewer extensively I’ve had to adapt it to my needs ……I found PDF difficult to edit unless you have the proper software…which no one seems to have, I most often had to convert to word and from there add the extra info i needed…… I also found that when working with local sound crews, some of the ilive info was of little use to the A2s…. (ex:bass drum goes to mix rack input A1 with direct out port b1 and inserts etc… ), adding the mic name/model, and/or the subsnake colour and # and whatever other info you might need, became more practical for set ups. A word or excel document would also be more useful as well as several blank boxes to fill as needed ….I uploaded samples of the 2 inputs versions, the output version also needed to show local patch points and # when required so again this had to be modified from the original ilive viewer template……
Screen-Shot-2017-03-28-at-11.38.51-AM.pdf (75.1 KB)
Screen-Shot-2017-03-28-at-11.47.27-AM.pdf (125 KB)
this is a remake of what i did years ago for the ilive,
became obsolete after this guy made his online show viewer
pdf is quiet cumbersome as for editing, i does work on a mac/pc
but not on mobiles like ipad e.t.c.
could make life a little easier on a little festival for the stagepeople…
it is a “rack input view” with dropdown lists for quick choosin, as well one can simply type in the in/out fields.
if there is a adobe live cicle nerd around,i can supply the xdp files….
the zip file contains 3 pdfs 32/48/64 version of the DM
Nice form… would be great to have something to edit it in other than PDF editor! Great work.
Would be great if could edit the drop down list to include more items to chose from??
i was thinking of that as well, in fact i am to stupid to figure out how to have the drop down lists getting their input from a external file (txt), therfore one could have (for example) classical music,folk, jazz “presets” e.t.c. and edit by themselves
anyway post a txt file with your suggestions (names) for the drop down list.
b.t.w. i tried to do it with html so one could use it in a browser …and gave up…
hows that…
https://megapeng.com/dropdown.htm
works even on my ipad1
just the inputs so far
Thats pretty good work… nicely done.
If there is a way still to edit the input label options to allow one to put other names in that would be great?
But good work!
i was fiddling for almost a day, ipad is so restrictive…
as i said post me suggestions what you would like to have.
there is a a read me how to customize in editor (simple “search and replace” job).
here is a zip file with 3 versions (dm64,48,32) the files have to reside within their folders (for the pics).
there is a read me file in it.
and of course if you have a friend who knows better than i do html scripting…feel free to improve it.
i still have to find out how one can store it on a ipad so you dont have to be online to use it
have a nice weekend
b.t.w. if you want to reset simply reload the page…
latest version here
Very cool mumu, where’s the zip file for editing? I’d just like a few generics like “DI #… / Inst #… Vox #…” for festival patch sheets
Oops, found the zip file, but yes if the online version is able to include that stuff it’d be awesome!
glad you like it,
here is the latest version (zip file)
please post names you want to have changed/added here ill do it, if you want to know why,right click on the page choose page properties, then you
ll see it…it is quiet a lot of scribble there…
- if there is enough interest i`ll make a android/ipad app out of it where all the stageboxes are included (64/48/32)
- it is “promised” by ah, there will be a midistring support to “strip names” that would make it easier to even send and recieve names straight from the system.
- still havent figured it out (html5 javascript noob here) how to get the same function like we had it in ilive editor
(make a comma separated list of the names paste em into the page/app and they spread onto the right inputs on the list) would save a lot of clicking and typing… - futher personalized lists i would charge 1 pound of costa rican cawfee and two packs of cigaretts (jarmush fan here…yessa koffee anda cigaret)
dm64.zip (156 KB)
Worth your weight in cawfee and cigaretts mate
awesome work… An App would be sweet if you get round to it…
