The DAW Control map is fixed, with the fader level, mute and PFL keys on dLive MIDI strips controlling the track level, mute and solo in Pro Tools.
Once you’ve installed the driver, set it to TCP/IP and HUI mode, and make sure it connects to the dLive MixRack.
In Pro Tools, set up multiple HUI interfaces as follows:
. Go to Setup / MIDI / Input Devices and enable all DAW Control MIDI ports.
. Open the Setup / Peripherals window and navigate to the MIDI Controllers tab.
. Create a HUI device for each block of 8 MIDI strips present on the mixer, and assign to the corresponding MIDI ports.
The following example assumes 16 MIDI strips are used:
. In row #1, select HUI as the Type and DAW Control MIDI 1 as the Receive From and Send To ports.
. In row #2, select HUI as the Type and DAW Control MIDI 2 as the Receive From and Send To ports.
. Click Ok.
Transport should be mapped, it follows Mackie protocol if I’m not mistaken. What interface are you using to get audio from dLive to Pro Tools? We jumped ship with PT for tracking because of the 32ch DANTE limit.
