'Drifting' Gain
Hello Everyone,
Over the last year, the maximum gain before feedback for my two phantom-powered mics has been gradually decreasing: 24dB originally for both for years, now 15dB for a condenser pulpit mic and just 8dB for a lapel mic. Both are now metering -20dB max on my Qu-24 PAFL LEDs; previously, they were usually at unity and occasionally into the yellows. This mixer is connected by dSNAKE to an AR2412 audio rack. Both are now 8 years old. Could this be an issue with the mixer’s phantom power circuitry, the AR2412 (rated to provide +60dB of gain), or something else? No changes have been made EQ-wise to these mics. (I should also mention all my other non-phantom power mics and outboard gear have normal audio levels, so I don’t think it’s an amplifier issue.) Thank you for your suggestions in advance.
Ron
How are you relating gain before feedback and the db levels you stated?
Is that channel preamp gain?
Try plugging the mics into a different channel.
“Measuring” a microphone’s level by its susceptibility to feedback is, in fact, quite unusual.
Do you get the impression that the microphones have become more sensitive - by significantly different amounts (9 dB and 16 dB!) - in terms of their feedback threshold?
In other words: Is the maximum volume still the same, but you simply need to apply less gain?
Or has “just” the susceptibility to feedback increased?
Does the “condenser” have a cardioid polar pattern, while the “lapel” perhaps has an omnidirectional pattern?
In this context, changes to the compressors could be a much more critical factor.
Try switching them off as a test.
Of course, a hardware defect can never be ruled out.
What happens if you connect one of these microphones not via the AR2412, but directly to the mixing console using a long cable?
Do you observe a completely different balance between the speaker’s level and the onset of feedback, or is the result essentially the same?
Changes in feedback susceptibility are usually rooted in room acoustics.
Does this still concern the same room as a year ago, where you suddenly encountered an issue with what appeared to be a longer reverberation time?
At that time, you also mentioned a window that was likely causing reflections.
Have the causes of this phenomenon been identified, or could it still be the same underlying issue?
Also, keep in mind that even factors like temperature and humidity can influence room acoustics.
As a precaution, it is worth noting that you could inadvertently create an electronic feedback loop within the console itself - for example, by routing an FX return back into its own bus.
-20dB makes me think of a PAD button . Did you check that your Pad option is OFF on channel preamp ?
Yes, thought about it also! 2 possibilities: In the channel itself or in an external DI box. Had this problem a few days before also…
Hello Mike,
That’s channel preamp gain.
I plugged the lapel mic into a different channel this morning - problem solved. I now have a signal that allows up to 35dB of gain before feedback, with the PAFL LEDs into the yellows (+6) - much better than just 8dB I had recently. Seems there’s either an issue with the channel I was using, or perhaps the XLR cable, which is 8 yrs. old. (Think I’ll try a new cable on the previous channel to ascertain whether or not it was just a bad cable or the channel itself.) As for the lapel mic, it’s a Shure WL183 omnidirectional condenser- I used a WL184M supercardiod condenser previously, but it was too sensitive to plosives, etc.
Thanks, Mike, for the suggestion!
I’d say the susceptibility to feedback increased. The pulpit mic is an audio-technica polar pattern (line cardiod) with a 90 deg. acceptance angle with “superior” off-axis rejection for maximum gain before feedback. The lapel mic is a Shure WL183 omnidirectional condenser. I believe this feedback susceptibility is due to the room acoustics, as you stated. The window at the rear of the auditorium is quite large - about 10 sq. ft., with a recessed metal frame of about 1 ft. deep. (This was intended to provide ambient lighting.) The church was well along in construction before I came along - I would have advised the pastor to not include it. As of now, the reverberation remains, but is tolerable. (Barely audible with a full room, with people helping to absorb the acoustic energy; you hear it more at half-capacity or less.) Heavy velour curtains would certainly help, but the pastor insists on that ambient lighting. Yes, there are wide variations in the temperature and humidity, too, so those are additional factors. I’ve learned to live with it - besides, that extra reverb makes for a more lively sound when I have a signing group of 6 or more. Just need to be careful setting the gain on the pulpit and lapel mics - just the minimum needed…
Still kind of hard to follow exactly what your talking about with the description you gave.
Yes you need to check cables and everything in the signal path.
Since your using a stage box the pad switch would be a good thing to check…if it is turned on before turning off be sure to turn down that channel.
You said moving to another channel seemed to take care of the problem, that would kind of indicate that it was no so much of a room issue.
While you can’t fix room acoustics with an EQ a properly set up system can make a big a difference with gain before feedback.
I hope you are aware that your new lapel microphone, due to its specific polar pattern, is significantly more prone to feedback.
If the switch took place within the last year, that could well explain the issue with this particular microphone.
This should certainly be very well suited for that purpose.
In my view, one should not expect a dry acoustic in a church.
Architects ought to always involve architectural acousticians who have experience with such structures.
Pastors and similar are generally not trained for this. :wink:
Furthermore, church music is typically composed with church spaces in mind.
At first glance, a gain setting of 24dB sounds really high for a condenser mic in a typical “live sound” setting (obviously that is a very generalized statement and the reality depends on the specific situation). 15dB and 8dB would be closer to what I would expect the gain levels to be set at to prevent feedback.
Is it possible that gain was previously being removed elsewhere in the audio chain - trim level, pad switch, EQ (where it is common to see people hacking out 10-15dB of gain across the entire frequency spectrum instead of simply turning the gain down and resetting the EQ), compression, etc - that is no longer being removed today? Or conversely, are you adding gain somewhere in the audio path (pad switch no longer engaged, compression makeup gain, etc) that previously you were not adding? Has the instrument or singer changed? For example, we have a “strong” singer that requires 10dB less gain than any of our other singers.
Edit- it seems that at least one of the mics is part of a Shure Wireless microphone system. Has the gain been adjusted in the wireless system by chance? Obviously that would have a direct correlation to the preamp gain setting in the console.
Long story short, there are at least a half dozen places where “gain staging” occurs that if adjusted would necessitate a change in the preamp gain too. I think the most logical explanation to the situation is that there was previously a gain staging “problem” that caused users to have to turn up the preamp gain higher than “normal”. That “problem” has been corrected/removed and now the preamp gains are closer to “normal”. I’m not completely ruling out a hardware failure/issue, but I also think any potential “hardware issue” is more likely to occur in the mic than in the console.
