Driving a Wi-Fi device
Good morning from Florida. We are attempting to provide hearing aid support to our venue through a Listen Everywhere device connected to our Qu-32. We are using the Alt Out but are not getting sufficient signal to the device. Would using a Matrix provide any higher level of signal out? Failing that, is there any kind of signal booster that might raise the output level?
Thanks, Phil
Using a matrix would work and you could apply some compression as well as EQ to the hearing assist feed.
If you have an open mix you could set up a post fade mix feed and on the mix sends for the spoken word mics run those a little higher than the music channels.
I have set a few of those systems.
Thanks, that is what I was basically going for.
Phil
