As well as looking after our iLive T112 and iDR48 I am also a drummer. I would really like to set the system up so I can adjust my own mix via my laptop. It seems to me that if I run Editor and hit the Mix button on my Aux this will also affect the surface which could cause problems if there is no communication (ok during soundcheck maybe but not during performance). What is the solution to this? If I can’t control my own mix I would at least like control over all the drum channels and click etc. (8 to 10 channels in my mix only). I’m looking at a solution that uses no additional equipment but will consider other options too. I’m aware of Aviom and similar products but we’re not ready to go that route yet.
Yes, I have looked at the PL controllers and there may be another discussion about the merits/cost of these compared to Aviom at a later date. In the meantime I want to explore the possibilities using my laptop.
There should be no problem as the editor and surface can work independantly. You can adjust your mix while the surface is doing the FOH mix at the same time.
As above, I wouldn’t think it’s an issue, as long as the FOH engineer knows what you’re doing - depending on how many channels you’re using for the mix you might even consider mirroring your inputs (say, using channels 33-64), setting to show trims on the Editor surface, and setting your monitor mix post fade - that way you can control individual channel eq etc as well as overall aux tuning…just a thought! I guess you’d set up a custom strip too, just to make sure you didn’t make any accidental changes?
As Biggsounds said…mirroring and custom strips with trims on surface…
Thanks for your help everyone, I’m going to try a few things this weekend.
Just to clarify, to mirror the inputs do I set up some new channels patched to the same inputs? I’ve done this in editor and so I now have my kit over channels 1-10 and these are replicated on 51-60, am I doing this right?
Thanks again and keep the ideas coming if there are any more
That’s right - I’d assume you’ll want more than your kit in there, but the principle stays the same - mirror the inputs (i.e. select the channel strip preamp section & simply assign the input to be the same as your actual drum inputs on the iDR), set that channel to show ‘trim’ on the surface (so you don’t accidentally mess with the FOH mix) and setup whatever you’ll need in a custom strip: the required channels, whichever Aux fader you’ll need, and anything else you require (eg are you using one of the FX busses for your monitor mix?) - every time you open editor that custom strip should be there ready to go…
Again, if you set the Aux to post fade you’ll have control over individual channel EQs etc, and as you’ll be the only one controlling these strips you can just set them to unity gain on the fader, and mix as per usual on the Aux mix controls…
I’ve been thinking about this kind of setup as I’ve got a touring act coming in October & I’ll be on stage running monitors from a laptop side of stage doing exactly as I’ve described (except I’ll be controlling 6-8 sends of monitors, but the concept’s the same)…
You are correct, I will want more than just the drum channels in there but I was worried about running out of channels. I was thinking of the inputs on the mix rack but in actual fact, there are 64 channels available.
If I didn’t want to share gain, how could I do that? I don’t think I need this but I want to understand the principle. I’m guessing that some sort of splitter is required?
If you do it in this (accepted) way you’re stuck with sharing gain… but then again how much difference would you need to have with the FOH engineer?
Let me back up - is this system always being used by the same group/engineer? If so, you’d assume that the gain settings are reasonably static from show to show - in that case the FOH engineer may be open to setting trims on surface at FOH too (once the gains have been set with a reasonable amount of headroom), which means you’re not going to get any sudden changes from them adjusting the head amp.
You’re right, if you don’t want to share gain you’re down to splitting your signal pre the iDR (i.e. into separate inputs), but I’d suggest you’d find it easier to have this conversation with your engineer than anyone on here
I’m happy with gain sharing as all I want to do is push the faders myself rather than have the engineer do it. As it stands, any change in gain would affect my monitor mix anyway and most of the time the engineer gets things right during soundcheck so there are no problems. By using the methods mentioned I will have more control and given that the kit has lots of channels this is important. Being stuck behind a drum screen doesn’t help with communication so this will be much better. As I said before, I manage the sound team and engineer too so I get the benefit of seeing both sides.
I think I’m pretty much done here now so thanks again for all the contributions [ ]
We frequently use 2 editors on stage independent of the surface mix. PAFL gets shared so don’t use that but mixes are independent (in the way you are using it).
interestingly, recently we ran foldback (8 x IEM + 2 speaker sends) from the editor (with an additional monitor) and a second system mixing another mix for the overflow room down stairs.
all went well although running foldback on editor is frustratingly slow.
