DT770 250phm through QU headphone jack?
Can anyone here confirm if DT770 250ohms would run fine via the QUs headphone jack or is sticking to 80ohms a wiser move? (have a QU24 if that helps).
They will work fine, you may notice a little lower output level compared to a lower impedance headphone.
For what it’s worth, I’ve used 250 Ohm DT770s with both GLD and SQ with no issues. No idea of the headphone amps in those are the same as each other, or the same as Qu, but it would seem like a pretty re-usable bit of design work…
Chris
