Dual MixRack Slave Returns
I thought had this working once but I am having issues with return patching with Dante in a dual mixrack configuration
I have a T112 connected to Port A of an iDR64 MixRack (Master)
Port B of the Master is an ACE card connected to Port A of an iDR16 (Slave)
Port B of the slave is a Dante card
I am using Logic Pro for record/playback
I have about 48 analog input sources, most on the Master but 8 or so on the Slave.
I can route Input-Direct Out sources for each channel from the Master to the Slave over the Master Port B ACE port and then map those out to Dante channels in the Slave. Similarly I can route Input-Direct Out sources on the Slave to Dante output channels. My recordings are working very well on all channels. So, output routing is fine.
I have the recorded tracks in Logic Pro mapped to individual output channels on Dante. Using a channel strip on the slave iDR (say #65) I can select any Dante input channel and hear the associated track just fine. So, I can map Dante inputs to Slave channel strips and that works.
However, what I want to do is map the Dante tracks that came live from a Master MixRack channel strip (1-64) back to the same strip.
To do that, I went to output routing on the slave MicRack and mapped the ACE output channels 33-64 to the Dante input channels I want to use. I then went to a channel strip on the master mixrack (1-64) andI selected the Port B Ace input channel mapped on the slave. However, I get no signal back on the Master mixrack when I do that.
I also tried using the same return path idea over ACE using local inputs on the Slave mix rack. Again, no success. In short, it looks like passing a signal back to the master MixRack from the slave over ACE just isn’t working at all.
Am I missing something?
I am trying to set up a quick way to do a virtual soundcheck so I can train new operators (this is in a church and is all volunteer so training needs all the help it can get). I figure I could create a mirrored setup of strips on the slave mixrack channels but I was trying to avoid that,
Mark
Mark Turner
T112/iDR64/iDR16/Dante
MixPad, OneMix
Mac Mini/Logic Pro 9
Hi Mark,
Make sure you have your Redundancy settings right on the Master rack. Go to Mixer Preferences, Port A/B setup. You should use Redundancy Off (All Inputs on Link 1), provided you are running V1.9?
Hope this helps,
Nicola
A&H
Thanks Nicola.
I will give that a try tonight.
Yes, I’m fairly certain we are running V1.91. The system was just commissioned on May 14.
Mark Turner
MixPad, OneMix
That fixed it. I should have thought to look there.
Thanks again Nicola!
Mark Turner
MixPad, OneMix
