Dual rack mode routing problem
Hello. I have a problem with dual rack mode. I can’t send the slave input chanels to the mixing buses including pafl. I think that is a ESB routing error… Any ideas? [:sunglasses: ]
Solo se que no se nada
https://allen-heath.helpserve.com/Knowledgebase/Article/View/211/0/understanding-dual-rack-mode-in-ilive
This might help, which version of the software are you running 1.83 should be pretty seamless.
Where in Argentina are you based?
Ian B.
You mentioned ESB -
If you are using Modular MixRacks with an EtherSound card in the top slot (port-A) of the RAB in the Slave Rack, then you need to pay attention to the ES card routing setup (maybe that ES card was used in port-B before?) Connect EtherSound Monitor program to the cards and check the signal flow for 64 channels in each direction.
please do not adjust your set; normal service will be resumed as soon as possible!
wich systems do you use?
SRV-AVB
R-72, iDR-16, xDR-16, Dante
