Hello
I would like to create the usual ducking from my vox to my reverb. When I open the side chain in my channel input vx I’ve no access to my reverb FX return but group or aux.
That s means I have to put my reverb in a group, it is the only solution.
Thanks for your answer
Hi
You can also use normal Inputs for the Fx which you wanna duck… you lose Inputs but you spare bus outputs…
Thank you Mat420, it is a good idea too.
I use multiple FX for my Vox and I feed all my returns into a group so I can do some BUS compression and ducking. Is there a reason you cannot use a group?
You could also go old school and send your vocals to an AUX, apply your FX on the insert, make it 100% wet and duck on your compressor.
